Alarm/central locking question
C
C180 Chris
Hi All,
Just wondered if anyone has had the same problem as me with the central locking/alarm
When i unlock the car i need to wait a few seconds for the car to unlock and for the hazards to flash to say its open, if i open the door before it has fully finished its sequence the hazards start to flash and the car immobilizer cuts in (red and green flashing lights on mirror) I then need to lock the car (remote) and unlock it again this time waiting for the hazards to flash and finish the opening fully.
It is only a few seconds but means that you can not open the car and jump in
Keyfob batts seem to be good (good strong red light at keyfob)
All the best,
I would have said that on either the drivers door or passenger door the locking mechanism is becoming to stiff, and we have this before just recently on a 140.
I would take the door cards of and spray some PTFE all over the locks on the inside
C
C180 Chris
Thanks Malcolm,
I will give that a go!
All the best,
mikestrivens
Stockport
Malcolm
Please could you send me the door card removal instructions for W140 and W124 as I want to oil and replace a couple of door straps (graunching noise) and also look at replacing the rubber trims either side of the glass as they are now hard and scratching the glass.
I have sent the 140 back and front,,,see what I have on the 124 later
