Alarm problem on C220
apecher
Hello,
my alarm goes constantly on of my C220 from 2000.
Any idea on how I could temporarily switch it off or quickly repair it?
Many thanks in advance!
Arthur
Dec
Ireland.
W202
Is the car a W202 or a W203.. Click on the W202 and W203 links here.
Alarms have a means to switch off internal motion sensors if fitted, there will also be some way of switching off the whole alarm system so as to cope with faults just like yours.
Dose the alarm go off when you lock the car or when you are driving?
Dec
Its normally the alarm siren that goes down, you can unplug it to see
A
apecher
It only goes off when its locked.
How can I unplug the siren?
It would help me so much!
Thanks in advance,
Arthur
A
apecher
it's a W202 I believe.... (It was registered begin 2000)
A
apecher
Many thanks!!
Can I just unplug it and then ...no "problems" anymore?
You can just unplug it or replace it,around £80
A
apecher
Thanks again, but I had a look and it looks rather inaccessible.
Not by the top nor from the bottom.
Any special trick?
Take out, or remove the front part of the wheel arch liner held with nuts, with the front nuts removed it should bend out of the way, its near side i believe
Dec
Ireland.
W202
There should be some way to disable the alarm other than by unplugging the siren, a key and key switch perhaps, someone with a similar car/year might know or an MB dealer perhaps
Am not say that the siren is not the cause of the fault but it should also be considered that the cause could be a defective door/boot or bonnet push switch not fully closing.
Dec
A
apecher
All right, I believe it is deactivated!
Many thanks, you really helped me out!
I wish you a nice day!
A
apecher
Thanks a lot! It worked out great!
I really appreciated your help!
