Alarm Siren Updated
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by johno2004, Oct 22, 2012.
  1. johno2004
    johno2004 Senior Member
    644
    Dec 7, 2007
    Your Mercedes:
    SLK32 AMG
    Can someone tell me if the siren with a code 203 820 38 26 which is the code of my original is still available or has been replaced by A219 820 32 26 which is the one MB have supplied me.
    The reason i ask is the new one is totally different from original and does not fit, as original is bracket mounted and this one just has a bolt at the back and if i mount it it is proud of the air intake shuttle. I could make a bracket but i do not want to fit and it does not work and they refuse to take back because i have fitted it and £85 down the drain.
    I have attached a photo
  2. whitenemesis
    whitenemesis Senior Member
    17,978
    22
    Dec 21, 2006
    Your Mercedes:
    CLS55 AMG '05
    Looks to me you need to remove the bracket from the old one and mount it on the new one, using that centre bolt?
  3. EmilysDad
    EmilysDad Senior Member
    9,252
    2,779
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    +1 ;)
    Just replaced my Vauxhall's, it looks similar and was mounted to the original's support bracket.
  4. OP
    johno2004
    644
    Dec 7, 2007
    Your Mercedes:
    SLK32 AMG
    Yes i thought of that but did not want to fit until sure i knew for sure its the correct replacement. its half the size and weight but i supose thats just technolgy and things get smaller. I had some time in the morning i supose il just have to wait for them to ring me tomz and confirm.
  5. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    I cannot pick up on either of those numbers :(
    I looked under 170466
  6. Uncle Benz
    Uncle Benz Senior Member
    3,075
    1,494
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    It is the right one. Use the bracket, but you will need a tool to fit the tamperproof torx bolt. The new unit is supposedly better at keeping water out, but will give you bleeps on locking and unlocking unless you change the country code with star machine.
  7. whitenemesis
    17,978
    22
    Dec 21, 2006
    Your Mercedes:
    CLS55 AMG '05
    EPC shows A2198203226 as correct and current for the SLK32 AMG (170466)
    Interestingly the original part number shows only for the non AMG variants.
  8. OP
    johno2004
    644
    Dec 7, 2007
    Your Mercedes:
    SLK32 AMG
    Thanks for that i have just finished fitting it and it works fine along with the locking and unlocking beeps.
    Another job done
    Thanks for all replys and help
  9. brandwooddixon
    brandwooddixon Senior Member
    3,266
    106
    Jul 31, 2006
    Wolverhampton
    Your Mercedes:
    CL500 Bluefficency 2012
    Actually you just use a standard spanner to remove tha bracket and then with a pair of pliers to prevent the tamperproof bolt from turning you just twist the alarm body to undo it!
  10. OP
    johno2004
    644
    Dec 7, 2007
    Your Mercedes:
    SLK32 AMG
    Yes thats what i did
Share This Page
