I
Imp man
Hi there, I'm new on here but if you guys are anything like other forums then I know I can get some good advice.
My dad's friend has a 1996 E320 Coupe (auto). It's been sat for many months but previously well maintained. The last service was 18 months ago but has not covered much mileage at all since. He asked me to give the car a once over as he would like to use the car again now the nice weather has arrived. I gave it a good check over, all fluids were spot on, oil was not even black. Battery was totally flat so purchased a new one. Fitted the battery, car started first time, let it idle for some time and within a very short time you could hear the oil reach the valves/tapets and the idle dropped as expected. All running very nicely and happily purring away. Put it in drive and gently eased the pedal and she moved happily forwards and back and the brakes worked well. I left it with him that in my mind there was no problem with it as far as I could see and should go through an MOT without a problem.
Now for the problem... He's been moving it about on his driveway today and has sent me a text to say that:
'a lot of warning lights came on and stayed on, battery, brake fluid, brake pads, abs, oil too low, coolant too low, washer fluid too low and light saying exterior bulb out.
I'm assuming these have all come on with the engine running, he is not a stupid man by any means. Is there anything that would cause this and even better, is there any cure? I'm going to go and have a look and see what is going on. Would be handy to have a bit of a clue on what to look for as I'm used to my BMW and my classic cars, not sure if Mercedes have any quirks I should be aware of.
Any help gratefully received.
Pete
Pete
