The CLK uses an off set of around 37 and the E class almost the same.
The problem is that the 208 uses 12mm bolts and the 211 14mm bolts, special bolts are available for this and you must also take care over the width of the wheel
Thanks Malcolm, my car has 15" so was thinking of going to 16 or 17", but of course tyre price is a big issue. Maybe i will put a "wanted" add on the forum. cheers....Derek
