M80
- Jan 21, 2006
- Location
- Derbyshire
- 2014 639 Viano- 651, 5sp Auto. 2009 S211- 646, 5sp Auto.
You can say that again.
Totally agree Martin.As is already happening, the battery technology / capacity will improve.
It's not difficult to imagine the yufes of tomorrow wondering why us duffers ever bothered with ICE.
"The silly sods used to run gas through already complicated and inefficient engines to try and make them go fast, and they just blew up. It's no wonder they screwed up our planet."
Yup. The main problem with them is the erm... EXPLOSION hazard. Aside from that they do make an attractive powersink.There is a lot of research going on with capacitors which if proved viable should bring costs down substantially.
See also a real life vehicle application in the Fisker Karma.See diesel- electric trains, ditto submarines from the T class/ Balao class onwards, or the RN’s Type 45 DDG for how this works in practice
Yup, that’s it. Probably the best way forwards.See also a real life vehicle application in the Fisker Karma.
A car which uses electric motors to drive the vehicle and has a petrol engine to generate electricity .
The electric motors are 2 x 201hp and the petrol engine is 260hp. there are batteries mounted in the transmission tunnel. The car can be plugged in to make use of external electricity and then when additional charge required the petrol motor will take over the electrical needs.
In practice this means the car cannot be driven making use of all 400hp all of the time as there is insufficient electrical energy production available to maintain it but the whole concept hinges on the idea that on the road you cannot use all the power all the time and the petrol engine is able to supply the needs of charging the batteries when power requirements drop below 260hp (such as when cruising or going down hill).
There is no direct connection between the petrol engine and the wheels (unlike the BMW i8 for example).
50 miles electric only so not too shabby.This 'ere Fiska super car must only have space for a few Duracells.
M80. No, EVs are not intended to reduce petroleum consumption (that in itself isn’t a problem). They are- so we’re told- meant to reduce the pollution created by combustion byproducts.
Health vs resource use.I'm sure there is a subtle difference in there somewhere.
I'm interested to see how that works though I guess part of the equation will be a voltage higher than 230 or 415v. As P=VI volts or amps can be high but in practise its easier to transfer large amounts of power at high voltage rather than high current.Now charging in 1 minute. Being fed from a 230V source, or even a 415V if industrial would be a helluva current draw.
Also you can make electricity out of other things than carbon. Wind, tide, solar, nuclear etc.. Whereas an ICE is pretty much restricted to carbon based products (at least at present).Health vs resource use.
Unless of course there are two or more charging regimes - just as in the Tesla. The Tesla can charge from a dedicated supercharger or from a domestic socket dependent on whats available.To find the higher voltage an owner would be required to drive, if he still can, to a special charging location.
Seeing that that isn't practical then even if the original source is transformed to a higher voltage the original source must still carry the load of power V x I. The voltage at source is constant, within a guaranteed 2.5%. Transformers are very efficient so for simplicity power out equals power in, so the current will be very high at the 230V source to provide the power required for such a short time of charging, otherwise the car would only be capable of limited distance.
If you're travelling then you want a very fast charge so a 'supercharger' equipped 'filling station' is required otherwise for domestic purposes a slower charge at reduced rates.
Even this can be done at home is a supercharger which contains a large bank of permanently connected batteries to provide the current for home super charging - i.e the supercharger is permanently mains connected so on trickle but has the ability to dump all its power quickly into the vehicle when required. Not hard to do and needn't be overly expensive. Irrespective its no less inconvenient to go to a supercharger equipped filling station than it is to go to a petrol station (and without any nasty diesel oil all over the filler).
Agreed.There are too many of us.
Agreed.
The reality of course is that there is plenty of space on the planet for people to live and work; the trouble is that most of them want to be where people are, and there's no incentive to develop new places for where people aren't.
To be extreme, exaggerating to make apoint.
Developing for new communities in the Sahara, the Tibetan Plateau or the Outback wouldn't serve the designed purpose due to other factors, the extreme ones.
Parts of Africa will be requiring help continually as their environment doesn't allow for the continued life of those that attempt to live there.
The more friendly or easier supported areas can and will fill as we breed up our numbers, Las Vegas perhaps fits that one.
If there are less of us we become more manageable. The Govts of course want more to increase revenues and along with it taxes, because the peoples money of tomorrow is already spent.
