Jim2
- Jan 18, 2018
- 1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI
.. So I am clearly not a professional videographer, but here is a quick clip I recorded yesterday. Sorry it's a bit shaky at times, as the gimble on the camera has a mind of its own and I didn't want to knock it of any surfaces.
You will also see that on the arches towards the front end of the car that run perpendicular to the road are both a bit dodgy looking. They will need to be evened off and made a bit more aesthetic as they will be visible from the road.
Oh one note: In the video I say it's all clean and sound like it's finished but there were a few bits needing further treatment and this was prior to that. My mistake in the video.
One of the problems working in that area, and the chief cause of it having rust is that its where the inner and outer panels are spot welded together...you can even see some of the welds...they are at regular intervals along the line. and in the tiny gap's between the welds, water lodges and the corrosion begins,,,,so as I explained earlier, when air / water meets metal, rust is the result. Do what you are doing, and seal it as best you can. You will be fine.
