MarkOC
- May 8, 2023
- E320 CDI Estate 2003 straight 6
I’ve trawled the internet looking for answers and while I’ve implemented some of the suggestions, I’m still having an issue.
So, coolant, visit workshop warning comes up on the dash. It wasn’t getting particularly hot so I changed the thermostat. Now it gets hot but the fan works intermittently once it reaches temperature. Sometimes it will run for a few seconds before stopping, other times it will run, the speed will vary, but it continues to run until it decides to stop which is when the warning comes up again on the dash. I’ve unplugged the temperature sensor at the thermostat and the fan runs flat out, plug it back in and it stops, which I believe is correct. Also if I turn the aircon off while the fans running, it will stop and the warning comes up. So, the fan works, the temperature sensor on the thermostat is new and appears to be okay. There’s plenty of fluid in the reservoir. I’ve heard there may be another temperature sensor somewhere. The only examples I’ve seen are of a V 6, and they are on the front of the engine. Mine is a straight 6 diesel so I’m not sure if mine has this extra one or not. Any ideas, advice, suggestions or help would b Ed greatly appreciated. Thanks.
