another mouse
hopeful
clk cdi2.7 auto coupe 2005
not been online for a while ,hospital and recovery seem ok now ,so the afore mentioned mouse i had in the rear of the 02 ,c220cdi has returned with friends,ha . the noise is more of a grinding rubber sqeak as one would get on front shock top mounts. if youve had mounts go you will know the sound i mean,
the rear bushes all have been lubricated wd oil lithium grease etc ,noise persists . jacking the rear of the car up on the post ramp both wheels together the noise becomes a squeak like an old jack under pressure . know what , icant find the location on any bush
if any one can suggest or knows of this problem please let me know ,cause its now continuous rear end ,sound like a nylon bush squeaking
ajlsl600
france
Subframe mountings?
hopeful
hopeful
no it was not that , found the problem after replacing track arm and steering rods and tightening wheel bearing .and checking for mot( all due to blooming potholes that cant be avoided on a certian route cause it both sides of the road ,12 months now) The rear underside had been waxed and lithium ,wd'd no joy then powerwashed , the old sqeak went away when wet ,so tried a good soaking. It was arb bushes (new) removed and greased. blooming hell all that seeking for a couple of quid bushes
hopeful
hopeful
yes a nightmare to find glad it was not the hub cause just done one siezed and throew up all sorts of codes , got a shaft for the other side , bound to go . ha
www.W140.co.uk&www.r129.co
