Another Spring Gone!
M
MercAl
Put my C Class in to get the clutch replaced. The Indie called me today, to tell me that the cluthch is repaired, but the car has a broken f/o/s spring. What is it with springs? Is the C Class known for dodgy springs? This is the fourth spring I've renewed on this car, and the second on this particular corner. I've had the car 3 years, and to be honest, it sits in the garage weekdays, as I use the van for work. In fact, since it was MOT'd in March, it's only done 100 miles! The Indie reckons it could be down to red chips in the driveway, catching in the tyre, and falling into the wheel well, then getting jammed in the coils, and subsequently causing the spring to fracture when under stress...(or something like that). To be honest, it sounds like a pile of pants to me...but then again, I'm not very technically minded! Has anyone ever heard of this, or had any experiebce with broken springs on their C Class?
Put my C Class in to get the clutch replaced. The Indie called me today, to tell me that the good news is...it doesn't need a flywheel. The bad news is...a broken f/o/s spring. What is it with springs? Is the C Class known for dodgy springs? This is the fourth spring I've renewed on this car, and the second on this particular corner. I've had the car 3 years, and to be honest, it sits in the garage weekdays, as I use the van for work. In fact, since it was MOT'd in March, it's only done 100 miles! The Indie reckons it could be down to red chips in the driveway, catching in the tyre, and falling into the wheel well, then getting jammed in the coils, and subsequently causing the spring to fracture when under stress...(or something like that). To be honest, it sounds like a pile of pants to me...but then again, I'm not very technically minded! Has anyone ever heard of this, or had any experiebce with broken springs on their C Class?
This is nothing to do with stones, the most likely cause is that the tempering is wrong, on a whole batch.
tempering springs a specialist job, a bit over the top and they are brittle, either that or the seat that the spring sits on is deformed, some where I have seen a caution when changing them, I will try and find it
M
MercAl
Thanks Malcolm. I'll watch for your post and take it with me to the Indie.
Appreciate it...Thanks.
Is your car a 202 or 203
M
MercAl
This is where I get confused! I'm pretty sure it's a 203 Malcolm.
I have found the spring install for the 203, there are a couple of points to watch,
I can Email to you
Not what I thought but something to look out for
As Blobcat mentioned elsewhere the chance are is that the indie is using a non MB spring, buy your own from MB, I cant re call broken springs on a 203 here before.
So nice having a head with different thinking on some of the threads:D :D
M
MercAl
Thanks for that Malcolm. I really appreciate your time and effort. If you would be so good as to email me, I would be obliged. I'll ensure it's MB springs that are fitted.
I've PM'd you my email address.
Thanks again Malcolm.
BlackC55
South coast
C43
I have done a few now on 203's. Not mega common but still happens.
mercman_1
Central Scotland
Front Springs
Just replaced both front springs on our W203,£100 the pair from the dealer had to wait three days for delivery.
Bob.T.
Dosco
W211
Front Springs
:roll: W211 front springs are also prone to breaking, even when the car is stationary, info from a well respected Indie following a failure on a W211 E220CD. :(
M
MercAl
OK...So it would appear I'm not alone in the spring replacement department! I'm off to collect the car now, and I'll be quizzing him about this in some detail.
Update to follow!
Update to follow!
Talking about your problem today with MB this is not a common problem
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
My wifes 203 (2001) has had springs replaced twice in the first 5 years from new. I think Malcolm has it right about incorrect temper but the batch must have been very large. The car only does about 5000 miles a year and is driven very carefully. Perhaps the spring rate has been incorrectly calculated. I always change the pair of springs rather than individual springs.
By the way I have not had chance to look yet, but there is another intermittent knock, could it be again?
