Anti-Freeze Mixing
Vx-Man-G
C-Class CDI
Guys,
After some quick advice please.
Not Merc related and asking for a friend.
Car has pink'ish coolant. Have added bue Anti-Freeze for winter.
Any issues with mixing?
I know I have personally done this in the past on some older cars without reasling there was any significant difference, and not noticing any real difference.
I dont always believe everything Google tells me, so after some advice.
Thanks.
EmilysDad
Bury Lancs
ML350
The colour of the coolant is not always an indication of the type of anti-freeze. I know that it's possible to mix them & end up with a gel.
ajlsl600
france
In my experience ,if you dont have origional container to see spec,make up.
warm motor,drain and fill up with clean water run, drain then refill with known amount of new stuff test,forget.
robin.large
CLS C63 AMG 2013
Modern engines are very specific on coolant, depending on metal, plastic, and rubber that it is in contact with and the temperatures and pressures.
Mix the wrong stuff and as others say, you will end up with gel.
Drain, fill with clean water, run engine until up to temp then drain.
Then fill with manufacturers recommended premixed coolant.
Sent from my ONEPLUS A5010 using Tapatalk
Botus
S500/2010/500
GM actually went bankrupt over this and the car company was wound up
they built gaskets that didn't agree with the coolant and all the engines went wrong..... it was officially wound up in 2009 (part to get 33 billion to help it cope with the engine replacement hell and partly like most America corporations it was run like a joke until the financial crisis bite to hard and they couldn't weather both storms)
bought as a going concern and carried on as new GM https://en.wikipedia.org/wiki/General_Motors_Chapter_11_reorganization
DREAMER NO2
W124 2.6E M103 1989
The type of inhibitor to be used will depend on the type of car engine you are uesing it in .Some dont like this,and some dont like that .
I see nothing yet to say what engine this is needed for. Some are yellow some pink some blue .I just go for G48 .
RhodieBill
Central South Coast. (Previously Out of Africa).
2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
Pink/Red is usually an "OAT" type AF. Definitely not to be mixed with Blue. Best to go like for like.
But at the end of the day it's your car so you can do whatever you like really. In which case there's no real point in asking...... :)
