Anyone tried to bulb up the other rear red fog lamp?
PINBALL
East Grinstead
www.coin-opcommunity.co.uk
124 E230 / 124 E220 /124 E280 /210 E320 CDI Wagons
If so, what happened, & did it have any effect on bulb failure warning lamp / relay?
Are the latest new cars only fitted with 1 working rear fog lamp?
Or was it only the 'E' class that had the nearside blanked off.
Thanks,
Keith.
Myros
R107, S211, R170, C219
94 C280
also blanked off. All I had to do was bend the metal bit of the mother board down which provided feed, pop in a bulb, and presto chango, stereo fogs. No effect on the computer, and neither did adding a high-level brake light.
PINBALL
PINBALL
East Grinstead
Thanks Myros
Stereo Fogs! & an "eye level" brake lamp fitted!
Which, Where & What brake lamp used?
Easy to fit?
Wher'd you get it please?
Must admit that when trailer fitted, all extra bulbs in circuit line work fine.
Keith.
Myros
I got one of those
slim wide multi-led ones from Ring lighting, cost about 6 quid, although I'm sure mercman or Dronsfields will have a Merc original if you ask nicely.
Go for the merc and you're better off having a new brake light switch, it has a feed for the high-level light built in, so you don't need to butcher any wires.
It was easy to fit anyway, as I just mounted it in the rear parcel shelf, ran the feed along underneath and then to the left light stack and piggy-backed onto that.
Tel: 020 8863 9233
