david arthur
after countles recalls on brakes and gearbox my 03 E200 is still not fixed its all well having nice shiny showrooms and refreshments but if they cant fix problems because the computer says no fault the robots dont no what to do.Two years ago i said my e class was dangerous it wanted to pull away on its own in stationary traffic only in cold weather.To the point if you did not brake hard you would drive in to the back of stationary traffic.The problem is so severe the car would allmost stall.Well it went into the dealership for 4 days they said they had cleaned out a minute ammount of swarf and refilled with clean oil and filter.Guess what when it was tested it did fault on the mechanic he said if he was not aware of the problem he could have drove into the back of someone. then said he would have to e mail merc as they cant talk to them direct anymore and i would have to rebook my car in again after christmas. On the 9th january it went in again this time they replaced a valve in the tork converter road tested again and said the fault was still there but not as bad.This time apparently they ordered a new tork coverter which they fitted the next day but once again this did not cure the broblem allthough it was not as bad they said merc then told them to put in a new special oil which he said he was surprised they had. Now ive been told to run it for 500 miles to see how it goes.They said they had an ML with the same problem worse than mine it wanted to drag the car over the road.They put a new tork coverter which did not cure the problem so ended up putting a new gearbox in.What i am worried about is my warranty runs out in june and will i be left with a large bill if the gearbox goes.I think it will be my first and last mercedes ithink i will be sticking with:evil: BMW next time.Any other guys with similar problems ?.
