Are there any dangers when fitting Reversing Sensors to a SLK?
Brian23
EClass
I want to fit wireless (From cotrol box to display) Reversing Sensors to a SLK. It will mean drilling 4 holes in the rear bumper and then wiring them in. On my wife's MGF you had to disable the Airbag system before doing this. Is this the same on Mercedes and if so how do you do this. Will the wireless effect the alarm?? It will only be on when the engine is running.
Brian
Xtractorfan
S class
Im almost sure that the sensors are in the centre moulding strip, if so it can easily be removed and drilled. if so checK that your drillings line up with the holes in the bumper..
I would expect that the frequency will be different from the radio and alarm..
No it will not,,you will be ok
wiltsandy
South Wiltshire
2001 230K SLK
B
Brian23
EClass
Thank you for the info and detailed pictures. It should make it a little easier.
Brian
