Ian B Walker
Just fitted a cylinder head to a 124 230TE and the engine is dog rough. To make matters worse the silencer glows red hot, worrying isnt it? It also spits back through the inlet manifold when the throttle is tweeked. Valve timing is spot on, new plugs, leads and distributor cap fitted. Can someone please confirm my worst fears that an inlet valve has stuck open. No had a chance to investigate the problem fully as it happened just before I finished work. A Compression check was conducted last night showing 10, 10, 9, 10 bar. It has been suggested that the mixture may be way out (quite possible) and also that the injection distribution head may be duff (also quite possible). I am open to any ideas. Thank you in advance for your input.
