ASR light 500sl
shreik irl
The asr light on my 500sl(129) iluminates after about 5 mins of driving & stays iluminated until ignition is turned off. start aain & the same happens after 5 mins, any idea's?
mstar
errrr something ain't right there dude, what do u mean the ASR light stays on u mean on the dash?
shreik irl
ASR Fault light stays on, not the triangle ASR function light
I do not know what year your car is, your lamp is it an ASR lamp on its own or is it combined with the BAS if you have it.
Malcolm
shreik irl
its aug 1993, it seems to be just an ASR light!
panason1c
Somerset, UK
It might be one, or more, of the road wheels revolving out of sync with the others due to uneven tyre wear .....or one of the tyre pressures very low which could be causing the ASR system to disable?.....
This is the nice thing with a forum, you get a lot of very sensible answers like this one, he has a lot of good points there.
Malcolm
davidsl500
Had a similar experience sunday whilst driving home on the motorway. top down, cruise set to 70mph (yes really !) and all of a sudden cruise turned off as the ASR lit up. Drove a couple of junctions further to be nearer home just in case and then switched off and on and no more problems - well, so far.... Tyres all okay so will have to see what develops. Changed a brake light bulb the day before..
shreik irl
Thanks for the idea's, the only thing is that i now realise, it happens after 5 mins of engine running, even when the car has been stationary from start up????
panason1c
Somerset, UK
There might be a clue in davidsl500 post.......check your brake lights are both working!....Could be that they are linked in to the ASR system and an 'automatic system check', after starting the engine, is picking up a blown brake bulb...(or defective brake light switch).
This could be total rubbish but at least it's worth a look ;) .
panason1c
Somerset, UK
Fixed now??........what was it?
shreik irl
no luck yet,
both brake lights working, will try a brake switch over the weekend
Cobben
Holland
Do have a nice sound sytem in your car, proberly the answer is there.
