- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
These dipsticks are quite a clever design by MB.
For the gearbox, the important oil level is the distance between the oil pickup and the oil's surface. The oil pickup is mounted to the body of the gearbox, not to the sump. The sump is a loose tolerance pressed part fitted with a flexible seal - it's not a good datum for a measurement.
The difference in tolerance is going to be no more than 1mm
The level is around 2 points with a 10mm spacing.
Since a thermometer is not used to check the temp a difference of 1 mm from a height of fluid at 5,6 cm is going to make no difference at all
It is a sump and nothing else
