Kally said:I just got an A class yesterday, it has the Audio 20 but no CD changer. I've burnt about 6 discs every way I can think of but it isn't reading any of them.
What am I doing wrong? Any help would be greatly appreciated.
Casanunder said:Hopefully not teaching you to suck eggs, here...
Are you burning the CDs as audio CDs or as MP3s as suggested by your posting title? Unless your head unit is specifically designed to play MP3s i.e. has an MP3 decoder, you'll have to burn them as audio.
Also check the type of media you are using - I find I have more luck using CD-R media (write-once) as opposed to the re-writable stuff.
nialler said:Change to a decent brand of CD and try that my audio 10 plays burnt (audio cds) no probs, I burn them from iTunes (Mac vers).
nialler said:alex are you burning a session by any chance? i.e. all cd's are multi session, they're so cheap I burn everything as single session or in Toast terms (write disk) setting is DAO not TAO, should be somewhere in Nero on the PC.
Selecting an MP3 track
MP3 CDs can only be played in the CD changer* drive.
Use the buttons on the multi-function steering wheel.
Switch on the audio system (please refer to the separate operating instructions) and select the MP3 player.
You will find an overview of the menus on more.
alexspurs61 said:Hi Nialler - interesting point, although you've lost me at DAO/TAO I will investigate.
Just doing the one session - i.e. a playlist of (for instance) 15 tracks straight out of i-tunes own BURN command
nialler said:Alex don't mean to sound condescending but you have checked in your itunes prefs that you are in fact burning audio as opposed to mp3 cds, itunes burns both, might have it on my pc and I'll check it out, though I have had a couple of cd's that have not read, currently using a brand called hi-space, they work out about 8c(6p) or less a cd and using a panasonic drive, which I have to replace as it will not read burnt dvds anymore.
I'll check nero and if you need an installer email me, I've peeeed around with my dvd/cd drivers on the pc to get the sims running for the girls so not sure if it is dao/tao but certainly something similar.
