Audio 20 not locking on to stations
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Phil Croucher, Mar 14, 2019 at 6:44 PM.
  1. Phil Croucher
    Phil Croucher New Member
    3
    Thursday
    Troon
    Your Mercedes:
    C320 2004 W203 17K miles!
    Hi there - new member here with my first Merc - lovely but the radio finds it very hard to lock on to stations - I can just about get radio 2 if I stand one leg with my finger in my ear :)
    Anyhow, reading around I can confirm that the doors unlock from at least 10 m away, although the boot needs the key to be nearby. Fuses are OK as far as I can tell. I would use one of those bluetooth thingys for the phone except that the radio won't lock on in the first place. Quite happy to get an Android unit or whatever, but when it works the radio is excellent so I would rather keep it. CD is fine.
    Would appreciate any thoughts - BTW - there is no tinting on the rear window.
  2. SH0X
    SH0X Senior Member
    126
    Jun 13, 2012
    London UK
    Your Mercedes:
    W204 C250D Coupe / Ex SL500 R230 - CLC V6 - Crossfire V6 - W203 C230k Coupe
    Hi & welcome
    With my audio 20 if im correct in remembering (CLK facelift / C w203 /CLC) I took the radio out and installed the AUX adaptor which allowed me to plug into that directly (also used the Bluetooth aftermarket £10 things and worked fine)
    Your ariel may be damaged or wires pulling
    See DIYs for removing dash trims or removing strereo / upgrading
    Worth a check
    use a cloth when laying the stereo down as it can scratch the dash trims
    best of luck
    hope this helps
  3. OP
    Phil Croucher
    3
    Thursday
    Troon
    Your Mercedes:
    Yes, it does -I didn't want to just replace the HU and then find I needed to change the amp anyway. But if I can fit an aux then I can use radioplayer on the iphone or at least fit a pure highway. If I find anything that will be useful to members I will post it - but it looks like the radio needs to come out. Believe me, I will be careful! How do I tell if it's facelift?
  4. SH0X
    SH0X Senior Member
    126
    Jun 13, 2012
    London UK
    Your Mercedes:
    Googles
    [​IMG] Facelift stereo (i think thats audio 20)
    pull the stereo out its the only way - must be a connection - and you can buy the aux inpuit plug on ebay I bought a few before - will change your life (have to active the aux port though theres a proceedure to do it (not sure off top of my head )
  5. OP
    Phil Croucher
    3
    Thursday
    Troon
    Your Mercedes:
    Yes, that's the current plan! The one I have bought fits into the CD changer (I don't have one on this car). Then I will use the Pure Highway 600 through the aux. Don't know why I'm bothered - there's no radio worth listening to anyway :)
Share This Page
