Adywheels
- Jul 27, 2024
- Location
- Berkshire
- C250 AMG Sport 2012 1.8T / Sprinter Campervan W906
Hello All
Got a strange issue that I think is the gear selector unit, below my symptoms & fault codes.
My main question is.... If it is the selector unit can I just buy a 2nd hand one and swap it out or does it need Coding in, i cant seem to find this specific answer about the coding so i'm hoping it could be a straight swap out?
C250 CGi 1.8T petrol
7 Sp Tiptronic Auto
2012 model
Selector lever part number - A204 267 7524
Stuck in Park.
Pressing Yellow button allows gear selection as normal.
Once out of Park the car drives through gears correctly.
Seems to have a bit of a snatch/jolt between Gear 1&2 at about 10mph.
After driving if put back into Park, you need to press yellow button again to select gears.
Dashboard display shows correct gears selected as you drive.
Tiptronic paddles work correctly in Drive (once out of park).
S-M-E button next to gear lever is unresponsive does nothing when pressed.
Car in E mode all the time, cant select S - M.
2 Fault codes (from iCarsoft CR Max Diagnostic) as follows….
U010100 – Communication with Control unit “Transmission” Has a Malfunction.
C103 – No CAN Message was received from control unit N15/5 (Electronic Selector Lever Module Control Unit).
Thanks in advance for an advice on this headache
7 Sp Tiptronic Auto
2012 model
Stuck in Park.
