And where is evidence of issues with cam chains from the use of stop start? There isn't even loads of speculation / rumours, let alone evidence of any issues.
FUD basically.
^^ +1 for meI leave it on 90% of the time and just switch it off when the type of traffic is going to annoy me. If you can control a brake pedal, then you can control when it activates in traffic, so rarely do I need to switch it off, just control when it activates.
Logic dictates wear must increase with stop start.Oh dear, still posting those same old links.
Yes they don't like it, yes they point out it doesn't really save much, yes they point out its about manufacturers meeting emissions targets. All true.
They also state it DOES NOT create reliability issues and failures. So again, where is there ANY evidence that it causes any issues.
So I can understand people switching it off because they personally don't like it for whatever reason. But to keep saying their cars are going to blow up (exaggeration I know) is just FUD.
As with all things 20% hate it, 60% don't care and 20% like the principle. Personally I sit in the 60%, but hate it when people are fed FUD to discourage them from using it.
..... Starters and ring gears (which are not lubricated by pressure fed oil) must wear more. It is possible to start an engine without using the starter (direct injection petrol only).
If we want to stick to facts let's not say it doesn't cause failures either.
If emissions were such a problem diesel as a fuel would have been banned long ago and the government would have done more to encourage LPG and CNG.
Never show weakness buddy , " they" will smell blood in the water .I almost feel guilty now, for stirring up the debate again
Good to know Alex , I hope an E350cdi convertible will be an option in a year or so . Looks like the stop start thingy started in 2013 ishYes, not on STAR though.
1. Chains are at their greatest tension when trying to open a valve from stationary. At running speeds momentum in the sprocket smooths the demands on the chain. Starting from zero all that energy to overcome the spring tension must be transmitted through the chain. On an engine with weak sprockets and or chains that can become an issue (OM651 or M271 anyone?) Indy's do seem to be seeing evidence of this.
2. Turbos don't like being deprived of oil while running - especially after high speed operation.
3. Even if the oil is hot it's not under pressure when the engine is off. Turning the engine and putting bearings under load when on a compression stroke must increase wear. Also when hot oil drains away faster than when cold and with modern low viscosity oils....
4. The more you use something the more you wear it out. Starters and ring gears (which are not lubricated by pressure fed oil) must wear more. It is possible to start an engine without using the starter (direct injection petrol only).
There are plenty of other potential sources of issues (heat soak, hot spots, heat cycles) as well.
All this is just logic. It may only be a small amount of extra wear but over 50,000 stop/start cycles it will be more wear than the same engine at the same mileage with fewer start stop cycles.
Not an issue for those who lease new and replace every 2 or 3 years but for those running older vehicles I bet it becomes more of an issue.
Start/stop is a great solution for a problem we didn't have. It doesn't accomplish much other than fudging emissions tests in the labs.
