autobox not changing down
Petemac
Inverness
merc c250TD 99/2000 150000MILES ON CLOCK GREAT CAR
going to see another c250 chap says box will not change down when this happens speedo stops working he stops car startup and away it goes again he did 48mls yesterday did it 1time only he replaced brake switch no differance but jest told me ABSlight is on would a faulty sensor cause this your thoughts on this please
PS last c250 i look at was no good i jest walked away
Yes a front wheel sensor if ABS and no speedo and the box locking up
P
Petemac
Inverness
thanks for that malcolm you sound very sure can i drive it home like that and fix it in my garage its 140mls away cheers
It has to be and we had one the same last week,, you still have normal brakes without the ABS,,,,, those 3 faults leave nothing else but the front wheel sensor probably nearside
P
Petemac
Inverness
i have sensor that i kept of my old c220d part No.a202 540 24 17 R IT WAS ON CAR 3MTS BEFORE I SCRAPPED IT WILL THIS FIT C250 1999
P
Petemac
Inverness
THANKS FOR YOUR HELP GOING FOR CAR ON TUESDAY WILL REPORT TO YOU THEN
P
Petemac
Inverness
malcolm it should not damage the autobox driving it 150mls home then i can fix it
I think it will be a slow journey if the box locks up, just take it easy and do not thrash it, thats all you can do, you can coast down the hills
P
Petemac
Inverness
auto box
well got the c250 TD home drove 170mls did the faults mentioned stop car removed key started car up no problem up throw gears but held on to 2 gear once and cleared its self with putting throttle up and down tested offside wheel sencor 2day with multimeter got a reading so it is alrite i think cleand lucterring through hole a lot of dirt came out will take a run 2moro to see and report back cheers to all peter
P
Petemac
Inverness
auto gearbox oil dark colour
took car for a short run today shifting up and down with ease nice and smooth even from cold checked oil very dark what is oil capacity if i drain from sump of box and what is the proper bulbs in main dash cluster as i need one for ABS cheers peter
PS.getting oil from merc dealer
Miffy
Bromley, London
CLK 320 CAB Elegance C208
If its very dark, should you not go for a full oil/filter change rather than just diluting your current oil?
