wscheffer
Hello everyone,
I sent my W126 1987 420 SEL over to a friend of mine that so happens to be a transmission mechanic for AMMCO (a transmission rebuild company over here in the states).
I asked him to remove my propeller shaft and to install new Flex Disks front and back, new centering sleeves both front and back, a new universal joint, a new intermediate bearing and balance it. Basically rebuild the entire propeller shaft!
The vehicle’s transmission was working correctly prior to raising the front of the vehicle and slipping a pair of jack stands under the vehicle at the front jack points. Therefore tilting the vehicle with the front end up in the air 14 to 18 inches.
After removing all obstructions we started to remove the propeller shaft...
First we disconnected the shaft at the rear by the differential. And then started to remove the front of the shaft up at the transmission.
We put the transmission in neutral and went to spin the shaft to finish it’s removal and discovered that the shaft will not turn.
It is as if the transmission is stuck in park! We put the gear selector back in park and started the engine briefly while moving the gear selector back to neutral to see if this would be the cure but to no avail this had no effect.
Any ideas as to what is causing the transmission to be stuck in park and how to rectify this problem would be greatly appreciated.
Thanks…
Oh by the way the transmission is a 722.324 :mrgreen:
Thanks…
