Automatic Transmission Oil Check or Change
MAAB
Hi.
My w202 220 Cdi estate has done 165K. It was 140K when I bought it last year. I have also check service book and other papers, I can not find if any previous owner had change the transmission oil. If it at all important to replace the old oil ?. I can not find in the car manual. Please advise.Thanks
mikestrivens
Stockport
It should be changed every 30 to 40,000 miles. It is probably long overdue if you have no record of it having been done.
As Mike above, this was never part of any service, and indie will change it all for around £165
amby
Mayo, Ireland
Mercedes E270CDi
Wondering would it be ok to use regular transmission oil such as castorl oppossed to genuine Mercedes Benz fluid? The Mercedes Benz fluid is over 3 times the price so I am wondering is there any difference which would affect the box?
nickcc101
Helston Cornwall
Suggest you stick with the MB oil or you may knacker your box. Cost of a recon box considerably more than the difference in the oil price.
These are the correct fluids
MB 236.10 ATF A001 989 2303...MB 236.10 001 989 2103..........
Shell ATF 3403-M 115
Mr Teddy Bear
Bristol Between Mill & Cutting
1998 W208 CLK 230K SPORT: MG F 1.8VVC: Flame Red Rover 216GTi
No it's not, unless you fancy a box rebuild???????:neutral:
124coupe
The dealers now follow this bulletin (so the expensive juice goes in the 722.6 boxes now).
Date: August 13, 2008
Order No.:S-B-00.40/89
SUBJECT:MY- All, Models All with Transmission 722.6 or 722.9
Operating Fluid Specification Changes for Automatic Transmission
5-speed automatic transmission 722.6
Only use the transmission oils outlined in specification sheet 236.14.
7-speed automatic transmission 722.9
Transfer case in Models 164 and 251
Only use transmission oils outlined in specification sheet 236.12.
I will get the fixed post up dated,,thanks
joe1972
Manchester
I've been using Shell ATF with success in my older cars.
I take it if they're doing a proper job they will change the converter fluid at the same time....hence the need for sump gasket in the costing?
The sump coming off does not help on the draining out of the old fluid,,the cooler pipe will have to be disconnected and the engine spun for a few seconds to clear the torque converter
124coupe
I know this will provoke a storm but here's the Merc list of approved MB236.14 ATF (the MB part number lists at £11-73 per litre):
nickcc101
Helston Cornwall
The Max oil you will remove, even after removing the cooler pipes and spinning the engine, will be 4.5 litres unless you have a torque convertor drain plug (as malcolm advises you don't). The 7226 box takes about 7 litres of MB oil on the initial fill only, don't buy 7 litres as you will be have 2.5 litres left over. I would advise that you stick with MB oil (as previously advised) or you may live to regret your money saving descision.
124coupe
The MB-branded part number is in the list I posted above - A 001 989 68 03 @ £11-73 per litre at list.
The two companies who supply MB are also in the list! (MB don't manufacture ATF.....).
Trivial fluid cost anyway when factored over 37,500 miles/60,000Km.
MB do it by putting 3 liters more in and then spinning the engine, then finish off by topping up with about 3 liters
MB dont do that at all Malc!! trust me, i used to work for them,
Drain it out and refill, thats the MB way!!
Thats what WIS says, I know that many do not charge for the full 7 liters
I know what WIS says Malc, but in the real world???????
