Aux Option - Where is it??
jd89
Manchester
e class coupe/2010/350
I've just bought a E350, there is a Aux input in the glove compartment, but there is no sign of an Aux option in any of the menus.
I've read through many threads on the subject but can't find an answer, I don't have a CD changer so there is no CDC button to press.
I've had a C class before so I'm familar with the menu on the mercedes, but the Aux option just isn't there.
Does this need to be activated at the main dealer?
Do you have a menu like Audio that you can scroll down, if the socket is there then it would have been activated
Do you have a radio or comand
jd89
Manchester
I have an audio menu, it has Radio, Music Registar, Memory card and CD, but no Aux!
I have command.
Wait till member NPUK comes on he will direct you to it
It is on mine
jd89
Manchester
Definately not unfortunately, I'm taking it to the main dealer at the weekend
Cannot you press on Audio and jet the list up
Billigmeister
E220 estate 2010
On mine i have to use the cd and the aux option is hidden in one of those options......took me a while to find it
Also the sound is a lot lower than other sources
Wheel
Hampshire
oldmusicvideos.blogspot.com
Mercedes B200 Sport
As above. On my Audio 20 I simply press the CD button to load up the CD player, and pressing CD a second time brings up the aux input!
