Auxiliary Battery
Clive Duberley
2008 e class 220cdi
Hi every one can anyone tell me I have a 2008 Merc 220CDI Estate is there a auxiliary battery on this model ? As not under pollen filter at front of car and unable to see anything in boot Thanks.
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Have you looked under the square black PVC cover in the tyre well under the boot floor at the 1 O'Clock pos'n?
C
Clive Duberley
2008 e class 220cdi
Yes that is were main battery is on my model Thanks
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
A 2008 E class (S211) doesn't have an auxiliary battery.
They were phased out, along with SBC braking with the 2006 facelift model.
C
Clive Duberley
2008 e class 220cdi
Great Many Thanks
Botus
S500/2010/500
yep,
as I understand it SBC removed the sensible reliable brake servo and replaced it with a pump and a gas sphere to provide the pressure to put the brakes on (much like a 747, RR and a Citroen). In case the sphere plays up the Aux battery can help put the brakes on.
They then went back to a proper set up everyone used for 70 years - up until the Ford Focus Mk4 brought the madness back superseding the brake servo with some electric module of hell that plays up, failing to put the brakes on at times and needs recalls and software fun
The SCB Aux battery, should not be confused with other Mercedes models where some have a starter battery under the bonnet and a bigger battery for interior toys in the boot.
ajlsl600
france
Look on bright side, one less thing and associated electronic crxx to worry about, a result.!
