Les Merc
- Jul 31, 2023
- C Class 2016 2143 cc
Hi , I have recently replaced the Auxiliary battery which is in fact a voltage converter containing 4 capacitors. I changed the unit and took the back off the old unit to see a small area of black which indicated that it had failed and that it was not something else. After this the stop start display on the dash display is still yellow with a line through it even though it had done over 100 miles . I did wonder if the fuse had gone but the suggested fuses namely 438,448 and 455 are all ok and so I wonder if the fuse description is correct. In fact the fuse box in the boot does not even relate to the pamphlet inside it and there are no references to the Eco start or stop start.
Any info would be appreciated.
