I have two auxiliary fans in front of the radiator which come on for added air flow when air con is requested at slow vehicle speed. I have just had my air con recharged and the specialist noticed that the air con fans did not come on until the gas was at a rather high pressure. When they did come on it was only for about five seconds before switching off. He said that the fans should have two stages. Stage 1 is when the vehicle is going at slow speed e.g. stationary. Stage 2 is when the coolant reaches a set point. The fans on my R129 500SL 1992 only come on for stage 2 apparantly. He suggested the problem could be solved by an automotive electrical engineer as he didn't deal with fans, only the gas side of air con systems. What needs to be fixed and can I do it?
Ray
Ray
