Hi group,
I wonder if anyone can help with a problem I have. The car is a 2000 registered W202 shape C220 cdi. The problem that I have is that on idle the top of the auxillary drive belt (between the power steering pump and the idler pulley on the water pump) vibrates and makes a brrrr noise. (best description I can come up with!) This is also very noticable when you take up drive whilst pullling away from standstill. The noise and vibration goes away when the engine is running at a speed greater than idle.
So far I have changed the belt and tensioner, inspected all pulleys for damage and rotated each by hand to ensure they are not stiff or binding. Everything seems to be as it should.
Then by chance, a discussion with an ex MB mechanic. He said it may be a freewheel pulley that they fitted to the alternator. Apparently they fitted this on later cars to avoid this very problem (due to the inertia of the alternator when it is not loaded) Whilst I didn't believe him at the time, the problem does go away when the alternator is under a heavy load. Anyway my local MB dealer say they know nothing about any of this and want to charge £90 per hour to FIND the problem let alone actually fix it when they do find it.
Has anyone else had a similar problem and may be able to point me to a cause? Does anyone know anything more about the freewheel pulley or may be able to point me to some information about this.
Many thanks in advance,
Duncan.
Duncan.
