Auxillary power socket in boot. W169
Biggles1957
W169 A Class CVT A180 2006 Elegance
I had a W168 in which I fitted a power socket in the boot. I'm sure I remember there being a pair of wires terminating in a connector behind the left hand stowage compartment in the boot (where the jack etc is stored). I can see what looks like a 'knockout' blank in the plastic liner in the same place in my W169 but before I start making holes I thought I'd ask if anyone knows if the wires are there hiding behind. Reason I'm asking is I've just fitted a towbar and am looking for a power supply at the back end rather than running a wire all the way forwards to the battery compartment. Wiring instructions on the relay box say to connect (via an in-line fuse of course) direct to the positive terminal of the battery, but I think I'd much rather it be on an ignition controlled circuit. I can't really see a reason for it to be permanently live? Any advice much appreciated!
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
What if you wanted to leave your sidelights on a connected rig with your car locked and unattended?
B
Biggles1957
I see what you mean but I only want to tow a little trailer to fetch stuff for my chickens so would never need to do that.
mattkh
England
A160 W168 1999 1.6
How much current are you hoping to draw from this supply..?
B
Biggles1957
Only for a small trailer Matt - so if the brakes and an indicator were on all at the same time that would be 3 x 21W so around 5 amps. I was going to fuse the supply 15A (maybe only 10A).
mattkh
England
A160 W168 1999 1.6
Thanks.
And the rear sidelights..?
I dont fancy recommending the fuel pump circuit, because in case of an overload, the car would stall.
How about the live to the aerial amplifier in the roof.
EmilysDad
Bury Lancs
ML350
is there not a SAM or fuse box of sorts at the back of the car without going to the battery? My ML350 (W166) has a fuse box under a rear seat with spare fuse points on the side, both permanent & ignition live.
mioba
Nottingham and Köln
Would the thin wires of a lighter socket be able to handle the current for a trailer (max would be fogs, no plate lights, brakes and indicator) at once I would say.
Be safe OP and check!
B
Biggles1957
I completely forgot about side lights! LOL! I guess because I won't be using it very often and the tip isn't open at night! What a plonker! I thought the lighter sockets were fused/wired for at least 15 amps or thereabouts? It's just a bit of a pain running a wire all the way to the main fusebox/battery but I'll have a proper poke around...
mioba
Nottingham and Köln
Just out of interest was there no wiring plug with the tow bar you fitted.
Surely its illegal (but I didnt look) to use a trailer without functioning brake lights and indicators at least.
@ZZZZ might have some info, although he’s not been around much lately :(
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Any wires in the boot will be on the ignition circuit, so when you turn your ignition off you loose your trailer lights.
I would run a cable up to the front of the car for power, too much risk damaging the harness.
