MJT1
- Jan 29, 2021
- B-Class 2013 1.8 Diesel
There was a minor collision, and car was in storage, after that no drive, I tried to check fusebox near passenger seat, found little mouse dropping , not sure what's the actual problemHello and welcome,
You might have a intermittent connection / break in the seat occupancy sensor, that will be the warning
The others could be low battery voltage related
Fuel systems and the like will switch off post accident and will need sorting before you can progressYes very minor
Ok will try to be in touch with mercedes specialist , is there anyway to drive the car ? So it will be easier to check the specialistThere are a number of collision systems built into Mercedes, which generally need reset after a collision, sometimes even a minor one.
You'll need to get the car to a Mercedes specialist for that to be done and assess it....
Not with your gear issue I'm afraid...where are you located?Ok will try to be in touch with mercedes specialist , is there anyway to drive the car ? So it will be easier to check the specialist
ThanksFamily-run Mercedes-Benz specialists in Nuneaton, Warwickshire | Mercland
Little further away but I'd give them a call and see if there's anything they can do for you. I'm not familiar with any of the independent specialists in Leicester sorry
