B150 Service Light Reset
D1983
Just done a service on a B150,how do i remove the service reminder?
Also it has the brake warning light on,i presume it is because brake fluid was due,this is now done too but i don't know how to reset them,can anyone help?
The brake warning lamp will indicate that the disc are worn and need replacing
D
D1983
Pads & discs are fine,brake fluid changed and level ok.Didn't look into it any further.
Any ideas on the service reset? I don't have the b150 model in my autodata.
I cannot help till later on this.
Going back to the brakes,,if a 2 wire sensor on the pads,one has come out or it has a broken wire. if a single wire then it is grounding somewhere, the fluid level is on the same circuit I think
Hertfordshire Merx
A160
Yes Malcolm is as ever correct about your brakes. I think it will tell you in your vehicle handbook how to carry out a service counter reset.
D
D1983
There are no books in the car,i've been looking all over the net for this reset procedure and can't find it anywhere....wtf :neutral:
