Just done a service on a B150,how do i remove the service reminder?
Also it has the brake warning light on,i presume it is because brake fluid was due,this is now done too but i don't know how to reset them,can anyone help?
Going back to the brakes,,if a 2 wire sensor on the pads,one has come out or it has a broken wire. if a single wire then it is grounding somewhere, the fluid level is on the same circuit I think
