B180 cdi indicator problem
Del Wooldridge
B180cdi
IMG_5794.JPG Hi All, I have an error up on the dash board, stating Turn signal right mirror.
If I indicate right the indicators works fine but the clicking sound is double the speed than if I indicate left. I have changed the mirror indicator unit although the original was was working fine to try and fix this problem.
Changed all the indicator bulbs for new....no difference at all....very frustrating. All bulbs and mirror indicators working fine.
Any ideas anyone
Thank you for your consideration
Regard Del
ZZZZ
Do you have folding mirrors (option 500)?
The wires are known to break, and if you have intermittent contact, this is exactly the type of error you'd see in the instrument cluster.
D
Del Wooldridge
B180cdi
Yes ...folding mirrors. Thank you I will try and find the break
ZZZZ
These might be useful:
  • 245 Electrical function diagram for power windows to 2008.pdf
  • 245 Wiring diagram for left front door control unit (DCU).pdf
  • 245 Wiring diagram for right front door control unit (DCU).pdf
  • 245 Wiring diagram of outside mirrors - Left.pdf
  • 245 Wiring diagram of outside mirrors - Right.pdf
D
Del Wooldridge
B180cdi
Thank you. It's definitely a dodgy connection. I changed the setting to stop,the mirrors from folding when the car is locked. So they are permanently out and that cured the problem...so I'm getting closer to the problem area. Thx for the diagrams
ZZZZ
Glad to hear that :)
Bear in mind, all the wires - nine for the option 500 - are black, from the door control module to the actual mirror, so go one-by-one (as in don't cut them all at once), to save on unnecessary testing later on.
Thick, silicone self-amalgamating tape is an excellent protection against future damage to those wires by folding / unfolding mirrors. Just over £2 from AliExpress: https://www.aliexpress.com/item/Use...Water-Pipe-Repair-Tape-Tools/32798239787.html Remember to stretch it (considerably, don't be shy) when wrapping the wires.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Self amalgamating tape great stuff, used to use it when I was mast rigging. Still have some in the garage.
D
Del Wooldridge
B180cdi
Thank you, that is excellent advice as I have known to rush in a bit quick from time to time !
