Back brakes wont bleed and pedal is spongy
raul2000
C200 w204 2.2d 2009
Hi guys, i have a mercedes c200 w204, 2009 and the rear break pipes broke in the same time, took it to my mates garage and we changed the pipes and pressure bled the system, now the pedal is spongy and only the front breaks work, we have bled the abs pump and master and we have got no air out of them
His diag tool doesn't allow us to use the bleed function, is there any other way to make them work?
Can anyone help?
M80
Derbyshire
What pressure does his bleeder bleed at.
I had similar trouble till I bled through with a 2 bar bleeder.
R
raul2000
C200 w204 2.2d 2009
About 15 psi
EmilysDad
Bury Lancs
ML350
I remember once trying to use an Ezibleed without letting the pressure down on the wheel ..... there was brake fluid everywhere!! :shock:
M80
Derbyshire
I didn't really get on with the Eezibleed. On recommendation I picked up a Sealey VS820.
R
raul2000
C200 w204 2.2d 2009
Well i just did another bleed with 20 psi on the rear brakes and abs pump as well, after the abs pump the front breaks have very good liquid pressure and the rear just trickles down no matter if i press the pedal or it has pressure from the bleeder, also phoned my local merc garage and they said I've done it right and it should work
I have no idea what to do now
Jason63
C63 AMG
The holes in the bleed screws could well be blocked which is preventing a decent flow. You'll need to take the nipples out and poke something through the small hole to clear it out.
You can try pumping the brakes whilst pressure bleeding. I'm pretty sure BMW say 10 pumps of the pedal if you have opened the system.
It does sound like there is air in the rear pipework or calipers.
R
raul2000
C200 w204 2.2d 2009
Thx but I've tried that too, i think ill just take it in to mercedes
R
raul2000
C200 w204 2.2d 2009
Welcome to wales m8
green lantern
1999 C208 CLK cabrio. 3.2ltr
Blocked flexi or you've left a clamp on one.?
R
raul2000
C200 w204 2.2d 2009
Is it more than 2 flexi pipes? The only ones I've seen are next to the master and those seem to be ok, no clamps left anywhere tho
EmilysDad
Bury Lancs
ML350
there's a flexi to each wheel's caliper .... there has to be to allow the wheel to go move up & down
R
raul2000
C200 w204 2.2d 2009
Those are fine, i didn't think to write about those too
w204benz
2012 C200CDI AMG Sport
I looked up the brake bleeding procedure a few months ago as I was having a bit of work done on them. Fairly certain WIS specifies the bleed pressure as 2 bar (29 psi).
Perhaps the last bleed was still at too low a pressure to get all of the air out of the system?
R
raul2000
C200 w204 2.2d 2009
  • #18
Wouldn't that break the reservoir? I'd do that too but im just a bit concerned I'll break it and spill break fluid everywhere
spenttherent
E220 Eclass estate 2008
It could be a load sensor restricting the pressure, if your wheels are hanging in mid air
M80
Derbyshire
Didn't on the 639 or the 211.
There wouldn't be much point in designing the 2 bar pressure pump if it broke cars.
