backlash in diff
philipll10
Hi I have a slight problem with my C250 TD estate, when selecting reverse I get a loud thump from the diff, I have told its a worn diff. My question is this, Can it be repaired or is it cheaper to replace?.
Cheers
grober
Scotland
W204 C200cdi estate
More likely to be worn propshaft couplings or differential mounts.
WG M-B
North west london
C63 Wagon in black
You can feel backlash in the diff easy enough
Pathfinder
Gourock
Cheers
or drive shaft / CV ?
Frontstep
T210 320cdi
Rear suspension movement.
Second opinion needed if you are unsure.
yorkshire1
East Yorks
"98 S202 C250TD Manual hybrid
thump
Cheers
one would expect the loud thump when selecting forward or reverse depending on circumstance, best way would to put it on garage ramp and check to see where the play actually is, worn diff would normally give rise to whining noises in normal drive and or/leaking seals
