Baffled By Idle
Chop 'N' Join
I am completely baffled by the idle speed on my car.
I have a 380SEC - 1983 UK Version.
When it is first started from cold, the idle speed is about 1400-1500RPM for a few seconds.
It is idling at about 1000RPM when the engine is at running temperature.
Any ideas?
Thank you for any help you can give.
TVRTASMIN
West Yorks
W124
Most cars will idle higher when started from cold as the coolant temp sensor will automatically instruct the ECU to richen the mixture.
When the engine thinks it is warm enough the revs will drop.
Parrot of Doom
Manchester
My Rover V8 engined Tiv used to do exactly the same thing. Quite normal.
Chop 'N' Join
Chop 'N' Join
That's true.
Except the correct idle speed should be around 700RPM.
It stays at 1000RPM when engine is hot.
There is obviously something wrong that it keeping it at this high idle.
Thank you for your input
Chop 'N' Join
Chop 'N' Join
You can't adjust up the idle.
It is totally electronicaly controlled.
Any other ideas?
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Agree,possibly an air leak. Check all your vacuum hoses for cracking as they will be brittle on a car that age.
Stevie A
Scotland
Can the throttle cable not be adjusted to increase the idle? It was just a thought.
Chop 'N' Join
Chop 'N' Join
Can't find any air leaks.
Used a stethoscope, found no leaks.
Tried spraying all the vacuum hoses and injectors with WD40 while the engine is idling to see if idle speed drops, nothing.
What next:confused: ?
