bas esp and abs lights on E240
uksamsung
Hi everyone, i am very new to this car
i bought second hand E240 W reg 3 weeks ago.
everything was fine until last week, suddenlly while driving the bas esp and abs light was on, when i restart the engine, the light was gone. however, i feel there is some "leather touching" noise at steerting when i turn, apat from that everything was fine
brough back to garage they change a new fuse or switch
however, today suddenly the three lights was one again and was off when i restart it. the steering start making some "leacther" touching noise again.
what should i do ? the warrany had run out from the garage.
is tehre anything wrong with the car?
how do i check if there is a fault with abs, esp or bas ? it seem everything was fine.
i am worried and any comment is most welcome
thanks alot
regards
alan
MB TECH WARRINGTON
thanks alot
regards
alan
could be anything, from stop light switch to abs/esp ecu, or anything in between, best advice take to mercedes specialist or dealer if none local, where are you located??
U
uksamsung
i am in Sheffield, South Yorkshire.
I am uncomfortable with the sound when steering turns.
U
uksamsung
thanks for your sgugestion. how can it be repaired?
jberks
Steering wheel off, pop a new one on and bang the wheel back. Had it done recently on mine. I'm not sure on cost as it was a warranty job but I can't see it being a lot.
However you're best getting the fault codes read to confirm.
I guess if its really shot you could hear it squeaking though mine never made itself known.
Alternatively on my W reg 240 I ended up with a new steering rack to fix a squeak.
Start with the fault codes though - hopefully its just the switch.
Warrington isn't too far from Sheffield so it may be worth a trip over the pennines ....
Sheffield eh - not far away from me .... Its not a tektite grey E240 is it .........?
