Battery/Alternator light
diarmaid
My c220 cdi 2002 with 108k miles has shown "Battery/Alternator Visit Workshop"
twice.
This warning has not re appeared.
I replaced the free wheel pulley last year,could a faulty pulley cause this warning light to come on?
Are there any tests I can do to determine what is wrong,I put the avo meter across the battery and it gave a reading of 12.6v stopped and 14.2 at tickover.
I have read other posts and they say that the regulator could be gone .
So my options are Alternator gone,
Battery gone,
Regulator gone
Faulty pulley.
Any advice would be appreciated from any other members I presume alternators rarely need replacement .Thanks again.
Diarmaid
This fault comes and go,s when the regulator pack starts to play about! new reg first, then alternator if that dont cure it!
panason1c
Somerset, UK
Mercedes ML270CDI, VW Polo 1.9tdi, BMW K1200RS
normally ,voltage out put from regulator,should not over 14v.
That's not correct...........the alternator normally charges the battery at between 13.5/14.5 volts.
As above nothing wrong with that voltage.
It is more of a brush pack that you can replace
panason1c
Somerset, UK
Am i correct in thinking that some 220cdi's are fitted with a water cooled alternator?.........if so, i thought that they are not diy repairable due to not being able to aquire the necessary parts.
panason1c
Somerset, UK
Diarmaid,
Your alternator output is fine............. if your battery is a few years old and tired it could cause the warning message momentarily when a heavy electrical load is applied on it. Certainly, if it is more than 5 years old i would renew it. My original battery 'died' at 6 years.
D
diarmaid
Thank you for all your advice I brought my car to an indie today as a ticking noise came into it I still think its the alternator pulley the clutch type,and yes its the water cooled version.
I will keep you posted .Is it very difficult to remove a water cooled alternator or can the pulley be replaced in situ.
Thanks again,
Diarmaid
Can be done in place!!! as long as it wants to come off!!
D
diarmaid
Dear all,
Thanks for your responses my indie has fitted a secondhand alternator as he says my old one is gone I am happy enough and it cost me 330 euro.
It seems a little early for this to happen at 108k miles.
Thanks again for all your help.
Diarmaid
