E
essdeeay
Hello, this is my first post here...
My father has a 2000 CL-500 4.2 V8, which has developed a problem where the battery drains flat if left for more than a few days.
He's had an electrician look at it and it's been narrowed down to fuse #61 (blue fuse, 15amp) for command centre (satnav/radio/cd changer etc.). There's about 0.5 amps of current drain on the battery when everything is turned off. When fuse #61 is pulled out, there is no current drain at all, but then you can't lock the car.
Any suggestions, or perhaps a wiring diagram which might help in a fix?
Many thanks,
Steve
Many thanks,
Steve
