battery location
shifty
may seem like a stupid question but am at a loss. battery has died in 00 e200 auto. cannot locate battery to attached jump leads. have seen in the engine block that below the air con is a box with a plus symbol. is this the plus attachment i'm looking for and if so where is the minus. need help.
Xtractorfan
S class
Battery is in the boot r/h side below the floor mat.. the plus symbol in the engine bay is the live feed from the battery..there should be a large nut on the suspension top which is the negative if u cant find it use a good earth point on the engine manifold or any non painted part
type49
Yes the red + is positive & anywhere on the engine that is a good hold will do to jump. Battery is under the rear seat. To remove seat base, find the levers at each corner of the base cushion (roughly pointing towards the pillar between the front & rear doors), pull levers up & pull seat up.
