"Battery Malfunction" Mercedez Benz C350e Plugin-Hybrid
Imran K
Trinidad and Tobago
C350e plugin Hybrid
Hi all,
I have a 2017 C350e Plugin Hybrid. I received a "Battery Malfunction" message. It was recomended that I change the rear 12V AGM start/stop electric hybrid battery. I purchased a new battery and changed it. However the "Battery Malfunction" message is still showing. I am not sure what is the next step to trouble shoot this issue or how to get this resolved. Has anyone experienced similar and solved. Looking for advice on solving this issue...
NJS5
Catherington, Hampshire.
2011 R230 SL350, 2016 Discovery 4 Landmark, 1973 MG B GT V8, 1959 MGA roadster.
Hi Imran - Welcome
Your profile doesn't show where you are from; if we knew this we might be able to make constructive recommendations.
NJSS
I
Imran K
Trinidad and Tobago
C350e plugin Hybrid
Hi, I am from Trinidad and Tobago. But the vehicle was purchased in UK and sent to Trinidad
NJS5
Sorry I've no MB contacts in Trinidad and Tobago - hopefully someone else will be along to help.
NJSS
I
Imran K
Trinidad and Tobago
C350e plugin Hybrid
Thanks NJSS for your reply. Hope somone else with similar issues can help me trouble shoot
Sakar
C350e plug-in
Hi guys,
I’m from the UK and have the same warning sign appear. Any help would be much appreciated.
2016 C350e plug-in
Frontstep
T210 320cdi
Sorry only do house calls..........................
C350e
Hope your problem was solved. The fault could be from the voltage regulator and not the battery. E.q. part no.: A 205 905 34 14 80
mioba
Nottingham and Köln
or does the warning simply need a reset once a new battery is in.
MB make is rather unfair for many things customers need a computer reset - instinct kicks and they go to the dealers wheras many other code readers would do.
akb
C350E
Hi, new to the forum. My car did the same, after a bit of investigation it appears that the main cable from the high voltage battery is rubbing against the body work causing it to short out. MB want 2500 to replace the loom, but local guy says he can sort for far less. Also there was a recall for this problem early in the cars life.
Frontstep
T210 320cdi
I would need an arm firmly up my back to pay that much to sort out a rubbed wire.
I wonder if there was/is a recall or even service advisory for what sounds like a fire risk?
akb
C350E
Apparently there was a recall some years ago, for a similar reason, which was done on my car. This is a new fault, may be related to the recall as in a similar vein, but I don't think enough has been reported to create a new recall.
