belt tensioner.
pvt
seaham
c180kompressor 54 1.8 petrol
hi all,I have a 54 c180 kompressor,75712 miles petrol.The problem i have is it has sheared off the bolt holding the auxiliary drive belt tensioner three times and unscrewed the bolt twice stripping the belt on each occasion.The tensioners are genuine M-B replacements as are the belts.Alternator bearings changed to no avail.all this has happen within 3000 miles,any ideas as to whats wrong?
Hello and welcome,, is the bottom crank shaft pulley running true
P
pvt
seaham
belt tensioner
I dont know if the crankshaft pulley is running true.car is with garage at the moment.will instruct them to check that out.
Robbostanhill
Dartford, Kent, UK
E270 Estate 2003 and *Her* C220 W203
Belts
I *strongly* recomment that the alternator mount be checked for alignment. Had a Sprinter that did 5 belts in 5 months, was the bracket that bent after the first belt went.
P
pvt
seaham
belt tensioner
robbostanhill.thanks for your reply.I will get this checked out.
