Dean Fletcher
- Mar 24, 2018
- Location
- Penrith, Cumbria
- Mercedes E400
Hi Chaps,
i recently found out that work i had done on the car last October is in fact unsafe causing the car more issues.
To cut a long story short - last October i had a MOT done the garage said you have play in the front right wheel and you need a new suspension arm to sort it out, i said ok how much, in the end it came to £239 and they told me they had used genuine merc part. soon after the i drove off i heard a knocking noise but didn't put it down to the arm as it was new. about 2 months later i took my car to another garage to look into the knocking noise they said they couldn't hear anything.
recently i had my car in at my local indy and asked him to have a look see if he could see out, he said that the suspension arm is causing the issue and its not a gen merc part. the bush is too soft causing the knocking noise.
So....... how do i play it with the garage that im not happy about, im in the middle of drawing up a letter explaining the issue, i could ring them or go and see them but i want to make sure everything is documented like postal tracking etc. plus they will just fob me off.
