ShivaYash
- Apr 29, 2012
- Location
- Berlin
- S124 1994 E200 (M111 engine), S123 1983 230TE (M102)
Dear all,
On my 1983 S123 230TE auto, I've begun flushing the engine prior to oil changes. This was mainly because of very loud lifters. The flushes have really helped and the lifter noise has nearly disappeared.
However, during the oil change, I did the flush (Liquid Moly proline) and drained off the oil. New oil and filter as usual. Within 60 miles or so, the engine has very low oil pressure. I removed the oil filter and fired the engine, oil pressure was back to normal. I concluded blocked a filter, replaced it, and now again, 700 miles later, I have the same issue. Oil pressure is low, 2 bar at cold, just under 1 bar when warm. On revs, the gauge only reaches 2.5 bar and not 3 as it did previously.
I previously used 10w40 high mileage oil, from Liquid Moly, and Mahle Knecht Ox 33d filters. Now I've begun using Mannol Classic 10w40. Both oils are MB spec.
My solution: while it is wasteful, I will drop the oil and do a filter change. I suspect the current filter is blocked, with carbon from the engine flush.
Comments welcome. I cannot continue to change filters every 700 miles!
Greetings from Berlin.
