Blue Efficiency HELP
weejazza
Registered
Scotland
Mercedes C180 Sport
Hi all, is there a way to switch off the blue efficiency on a Mercedes 350 I am worried that it will damage the starter motor as its constantly on and off.
eman
Walsall
21 EQC 400 Premium Plus
are you talking about the eco stop/start? does your engine cut out when you come to the lights etc. if so there should be an on/off button on the dash.;) the blue efficieny is just the engine name,(mercedes are doing there bit for the enviroment).
Carabosse
C300 AMG Sport Line Premium Plus Coupe (C205)
Is there not an ECO button for you to toggle it on or off.
Unfortunately there is no way of switching it off permanently... it's one of the first things I enquired about!
Oarsman
Norfolk
W221 S350L CDI Bluetec, Range Rover Vogue SE 4.4 TDI, 1963 Triumph TR4
Don't worry about damaging the starter motor.
If it's the same system as on my S350, I have been informed that the engine is restarted by the alternator using the poly v belt. Apparently the system puts voltage into the alternator and uses it instead of the starter
Hence that fact that it only operates when the engine is warm and the battery is fully charged.
toby1
West Berkshire
Blue Efficiency isn't the stop/start system AFAIK - it's the term for the engine
