Hi all, is there a way to switch off the blue efficiency on a Mercedes 350 I am worried that it will damage the starter motor as its constantly on and off.
are you talking about the eco stop/start? does your engine cut out when you come to the lights etc. if so there should be an on/off button on the dash. the blue efficieny is just the engine name,(mercedes are doing there bit for the enviroment).
Don't worry about damaging the starter motor.
If it's the same system as on my S350, I have been informed that the engine is restarted by the alternator using the poly v belt. Apparently the system puts voltage into the alternator and uses it instead of the starter
Hence that fact that it only operates when the engine is warm and the battery is fully charged.
WE HAVE NOW MOVED: 8 Hazel Road, Woolston, SO19 7GB Service, Repairs and remapping service Any queries, please do not hesitate to contactEmail@mbsofsouthampton.co.ukor alternatively you can phone Colin or Dave on 02380 445820, out of hours numbers are 07787913313 or 07907631681.
