Bonnet stuck one side?
shayes
as stated
Feel a bit foolish but having been working on removal and replacement of the Radiator I have already removed the central panel where the Bonnet locking mechanism goes into.
been upping and downing the bonnet for past few days, rem,oving parts etc
Got the underside panel off this morning but found I was unable to lift the bonnet the drivers side. Seems stuck fast. Why? The passenger side lifts ok
As I recall there is a post each side for the bonnet to stand on and get level.
Can't seem to get it to shift, but not tried with extra pair of hands. What can be snagging it?
Any ideas?
shayes
shayes
as stated
  • #2
Dont rain but it pours for me.
Thought maybe it to do with a vacuum line behind the removed slam panel could have got snagged in the locking spring. I did release it from the clips, but then why does one side of the bonnet lift and not the drivers side? Would expect consistency if snagging in centre. Doh
Can't of course see what the problem is. Maybe in darkness a torch but difficult as passenger side of bonnet will only raise an inch. I don't beleive it!!! What have I bl**dy done?
drmw
Yorkshire
www.autonomed.co.uk
don't know the car but given what you've said, I would try to lift the bonnet the absolute minimum allowing you to gently twist it & lift - one way then the other - in case one of the "buffers" has caught on some of the other paneling now the slam plate is out
shayes
shayes
as stated
Thank you I'll give that a try.
never thought about the system until now but these catches
http://www.ebay.co.uk/itm/FREE-P-P-...rts_SM&fits=Plat_Gen:W140&hash=item519d279883
are they released via the bonnet opening lever or are they independent of the cable.
Suspect one side is locked down
EUREKA !!! Having got a second pair of hands to pull the bonnet release handle the bonnet came free. What has happened is that in removing the slam panel the above locks are only affixed with one bolt and I guess were twisting rather than pulling back the release that particular side. Lesson learned - put back missing bolt temporarily as when cable out of clips and only one bolt there's less than necesary "pull back" to open the lock
Thanks for your thoughts.
Tel: 020 8863 9233
