Boost problem c220 cdi 2012
Omar Shazad
C220 cdi 2012
Hey......my car has gone into limp mode and computer indicates that there is a air leak somewhere.......i have replaced the intercooler pipe and the trottle body seals also the vacum transducer......but the same noise persists and is coming from left side of car......if sat in the car you can hear it coming from passenger side air vents...........can the intake manifold leak air......any clues guys????
.......its driving me crazy
O
Omar Shazad
C220 cdi 2012
You need to do a charge pressure test to confirm the air leak and then a smoke test to locate it, but its likely got a snapped inlet manifold bolt.
If it is a snapped bolt.....would i have to replace the full inlet manifold......if so do you know how much it can cost???
Steve@Avantgarde
Bristol/Somerset
Yes, the bolts are captive in the manifold and have since been modified.
Its roughly a £1000 job at an indie.
O
Omar Shazad
C220 cdi 2012
Do the bolts break in the engine block and need to be drilled out.......or are they pretty easy to remove and are snapped in the manifold itself......seem like an expensive dooo.....
