boot lid covered in condensation 190E
Steve-O
Everytime I Open the boot on my 190E the Boot lid is covered in condensation and when I lift the boot fully up, lots water streams out from the gaps / grooves in the boot lid wetting my Carpet.
Is this a common problem?
190e-nut
Yorkshire -UK
this has happened to all the 190E's i have had ... I would be happy if anyone knows a cure..from what i can tell any water should run down and out from the boot lock mechanism this is clear but still it holds water?
Steve-O
maybe one of them small batteyr powered De-Humidifiers would work?
tjo
most common cause was rear screen leakin, boot becomes damp and condensation forms on lid, check under parcel shelf next 2 hinges 4 water stains
tjo
there is a tiny grommet at bottom left corner of lid, if removed stops water gathering and pouring in boot when opened
190e-nut
Yorkshire -UK
yep I found the grommet...removed and threw it across into next doors garden ...hopefully it will work then i won't need my rear de-mister on all the time ;)
mercmonkey
Essex
Thats whats known as "filing" :D
What are you going to do when the garden nextdoor gets flooded:lol:
Malcolm
Ian Brown
Banned
Malcolm
I think that is easily answered malcom just remove the grommet:D :D
190easy
i take it you have a boot spoiler and if so its the mounting points onto boot (1)remove (rusty philips screws) spoiler and silicone contact points between spoiler and boot lid then re-fit spoiler and you will notice de-humidification within 6 months especially as summer will be here soon but remember the more you leave the boot-lid open in high temparatures (to expel old condensate) the sooner its sorted (p.s) if you don't have a boot spoiler i've just wasted 23 mins typing this (p.c illiterate)...ha-ha hope this helps....lol
Steve-O
Have a boot spoiler but only fitted it 1 month ago, screws are good and nice and tightly sealed
will try removing the grommet :)
thanks
mike65
Ireland
www.futuremusiccorp.net
Check the slats which are behind the number plate (you need to remove the boot trim inside). They might have been bloked off by a previous owner. (why is my post above the two below?)
Mike.
190e-nut
Yorkshire -UK
er...nope...no boot spoiler ...(sorry for wasting 23 mins..) but still good advice for when I fit one!!!
shayes
as stated
Personally in the Winter I always keep a tray of Salt in a footwell in the boot as per the Boat condensation priniciple, changing it every now and then.
Does it work you ask? well the Salt does absorb some of the moisture.
I noticed more dampness in the boot recently(and shoot me down in flames on this one) but I understand that the small fan under glove compartment ventilates the Sunroof area and flows on into the boot?
My connecting pipe was broken. It's not an easy thing to clip it into its place when trying to put on the Heater ventilator hose and somehow raise the part to get it to link into the Central Heater position.
Anyway, airflow was only circulating under the glovebox. Not sure if on later Cars things have changed?
190e-nut
Yorkshire -UK
Malcolm
Grommet removed from said garden after serious flooding in the rose beds...lots of slugs and snails have lost their lives due to my inconsiderate actions.... :-(
Ian Brown
Banned
Is the spare wheel well full of water?
shayes
as stated
since when was ANYONE ungrateful for getting rid of those wee beasties?
190easy
i suspect the same problem with my 190e and the mounting points on my rear spoiler look dodgy(i.e) the spoiler doesn't fit tightly onto bootlid i'm going to remove it and silicone the points of contact
Steve-O
  • #20
Nope, Spare Wheel well is dry. Going to have another look tomorrow or Saturday after work.
